matt
I got the cinemilled adapter for it for possible rig and creative mounting. Setting it up as a secondary camera if I can get it balanced right.
I dont get why everyone says its heavy, then again my main is a BMCC with redrock rig, around 25-30 lbs generally. Something i did try out though when i was testing manually tuning it was briefcase mode. Wish you could lock it into briefcase mode because I could see shooting it all day in briefcase mode with it resting on my hip. Its real easy, even have room to hold the remote control.
Hell if you wanted to, you could move the other handle up to the top in briefcase mode so you have two handholds, use the supplied mount brackets one in the middle to hold power distributor and monitor, and the other mount bracket at the bottom. Just get a cheap chest pad rig support to screw into it and you'd be flyin hawaiin all day. |
