Take off behaviour
411 7 1-12 07:35
AlanHd
Flight distance : 972454 ft
Up to now i have been flying using the N3 controller and i could have sworn upon auto take off and landing the drone positioned the gimbal down. Today i swirched over to the RC2 and the drone no longer does this on take off of landing, am i imagining the previous behaviour or am i missing a setting.
Thanks in advance .
Alan
1-12 07:35
Wyldwestaz10
Flight distance : 1099068 ft
The Gimbal on all three of my DJI drones are always at 0° pitch on take-off and landing for over 4 years. Pointing the gimbal down at -90° either way could damage the sensor.
1-12 11:26
DJI Gamora
Hello AlanHd. We apologize for the inconvenience you have experienced with the change in takeoff and landing behavior of your DJI Air 3S after switching to the DJI RC 2. We understand the importance of a consistent and reliable flight experience, and we are committed to assisting you in resolving this issue. To better understand the situation and provide you with the most effective support, we kindly request the following details:
[Screenshots] Latest firmware version for the DJI Air 3S and also DJI RC 2.
[Video Recording] Demostration how you get the gimbal positioning error during take -off and landing with DJI RC 2. Kindly you may submit the video recording via Dropbox or Youtube accordingly.
By providing us with these details, you will help us to accurately assess the situation and provide you with the most effective solution. If you have any further questions or need additional assistance, please feel free to contact us. Thank you for choosing DJI.
1-13 03:53
fgange57
Flight distance : 548399 ft
Norway
Both my Air 3S and my Mini 4 pro behaves the same both when taking off and landing.  Taking off, the gimbal always points straight ahead.  When landing, the gimbal points down (showing the drone shadow) until a couple of meters abobe the ground, then it straightens to straight forward again.
Have you done a screen recording to watch especially the landing, because it will surprise me if the gimble do not point down when commencing the landing.
1-13 13:32
tan8677
My Air 3s was just updated to the latest firmware and it also very sensetive to stick inputs and now it it show height limit to 150m or 492ft instead of 500m or 1640ft , my drone only flies to 492 max , is anyone having the same issues after an update ?
1-14 08:43
AlanHd
Well the good news for me is i’m only going half mad. The drone camera does switch to point downwards on RTH before straightening back up. I must have imagined it doing the same on take off.
1-14 10:05
$gambino$
Flight distance : 1563980 ft
tan8677 Posted at 1-14 08:43
Did u go through your settings in app after the update? It is imperitive that u do this because some of these updates will reset the settings in app
1-15 00:43
fgange57
Norway
On several of the updates, the settings are set to default, so after a firmware update, you should always check your settings.  Regarding the stick sensitivity, this is something you very easy can change.  Go to Control, and then to Gain & Expo Tuning. I have set all my settings to 0.15, making the movements to be less sensitive at the start and the more sensitiv when you push further.
1-16 03:32
