USB C Port Question
449 2 1-15 07:32
Pagemakers
Flight distance : 414377 ft
DJI, why have you changed the functionality of the USB C port on the N3 Goggles?
Previously, the port could simultaneously charge and output audio (using an adaptor). However, it is now limited to either charging or outputting audio.
1-15 07:32
DJI Natalia
Hello there! Thank you for sharing your concern with us. We are sorry for the inconvenience. However, upon checking on the issue, we can confirm that the DJI Goggles N3 does not support real-time audio transmission.
With that, we can provide you with the firmware release notes for the Goggles N3.
What’s New
· Added support for DJI Avata 2.
· Added Liveview Stabilization when used with DJI Neo.
· Fixed some known issues.
Notes:
· Restart the aircraft, remote control device, and goggles after the firmware update is complete.
· Note that the firmware update may reset various flight parameters such as RTH Altitude and Maximum Flight Distance. Before updating, take note of your preferred settings and readjust them after the firmware update is complete.
· If the update fails, restart the aircraft, remote control device, goggles, and the DJI Fly app or DJI Assistant 2 (Consumer Drone Series), and try again.
Thank you for your understanding, your cooperation is greatly appreciated.
1-15 11:36
Pagemakers
Thanks. I was asking about the purpose of using the N3 goggles for watching movies.
Previously, with an adapter, you could simultaneously stream the movie with audio and charge the device. However, with the current version, you can only either stream the audio or charge the device, not both.
I was curious about the reason behind this change in functionality.
1-15 11:52
