G0π
Flight distance : 36401 ft
Red_Dot Posted at 2-6 18:33
Actually you are right. Mini 4 pro is already their top of the line drone for their Mini Series and for under 250g category drone. All they have to do, is enhanced their software and hardware.
If ever a Lidar system will be included, pretty sure, the design will be revised.
I guess you are thinking about scanning LiDAR for 3D rendering?
As far as I know, every range finder for position hold and for obstacle avoidance, on the mini 4 pro are already LiDAR. It is is more stable and accurate than previously user sonar technology. It is used in conjunction with specific camera and treated by sophisticated algorithms. I may may be wrong or not complete then better to check.
On the other hand, adding a LiDAR Scanner keeping total weight under 250g would be a hard challenge. The other good point of the mini 4 pro is its upgradability to the next step category and in that scenario weight wouldn’t a matter anymore, but power and batteries capacity might be. |
