100w charger only for pro?
2077 14 2015-10-10
jellies
Is the 100w charger that comes with the Pro also ok for charging the battery that comes with the P3 Standard?(I guess - are the batteries the same between the Standard and Pro)
I read the batteries have their charging circuits buried in them so the charger is just dumb, outputting voltage on what
looks like two prongs. Does that mean I can hack the plug off and use a bench power supply at the same voltage?
Second question:
Is the default free app that comes with the Standard able to do waypoints + autonomous without the thing
doing a RTH the moment it gets out of range? (edit: it has dawned on me that the "autonomous" way point following only happens within the short controller range. Boo!).edit again: so it seems if you pay for the Litchi app (android only) you can put in a GPS autonomous course? is that the only way to that right now?
thanks!
2015-10-10
Stan1970
Flight distance : 105318 ft
I am not sure on the first question but on your second yes
2015-10-10
Stan1970
sorry just read again - when it goes out of range it will rth - that said not everyone has a distance issue with the standard - I always have sight of the craft but I am sure if you are in an open area and you lose sight of it you will not necessarily lose signal - dont believe all he haters
2015-10-10
Phantom Help
Flight distance : 228255 ft
All P3 batteries are the same.
When flying a waypoint mission (using any P3), the Phantom will continue flying the mission if it loses connection with the remote controller.
2015-10-10
sploodge
Flight distance : 809350 ft
Phantom Help Posted at 2015-10-10 16:29
When flying a waypoint mission (using any P3), the Phantom will con ...
This is changing in the next firmware thankfully.. Will be able to chooce what happens..
2015-10-10
jellies
thanks, so all P3 batteries are the same therefore getting a 100 watt charger on eBay should make charging time short even for a Standard.
2015-10-10
Geebax
jellies Posted at 2015-10-11 08:30
thanks, so all P3 batteries are the same therefore getting a 100 watt charger on eBay should make ch ...
You might want to consider that using a charger other than a DJI one will void your warranty.
2015-10-10
DJI-Dave
Yes and yes for you first 2 questions
2015-10-10
DJI-Dave
jellies Posted at 2015-10-10 14:30
We recommend DJI charger only.
2015-10-10
jellies
DJI-Dave Posted at 2015-10-11 08:45
Yes, I mean, a DJI "100 watt" charger .. they are sold separately on eBay, I think.
The thing is when you look at the description for it, it says "compatible with Pro and Advanced ONLY", but if the batteries are the same, then I don't see why that doesn't say "compatible with all DJI Phantom 3".
2015-10-10
RedHotPoker
Flight distance : 165105 ft
I bought a second DJI 100w charger a couple weeks ago. GLAD that I have.
With four intelligent flight batteries it's much faster, charging two at a time.
And on the rare occasion where the charger is already in use charging the radio controller battery,
I can still have one battery connected on its own charger, cutting down on my charge times significantly.
RedHotPoker
2015-10-10
jellies
I'm coming from 3d helis where I have octopus cables, a huge power supply (two 12v ex-server psus strapped together)
and two 1000w ichargers .. I was able to charge pretty much anything in any quantity at 5c (sub 15 minutes).
Its a bit of a culture shock to have to go back to 80 minute charge times for one small 4s cell
2015-10-10
DJI-Dave
jellies Posted at 2015-10-10 17:35
The thing is  ...
Maybe they got that verbiage before the Phantom Standard came out.
Then they never bothered to change the verbiage for the add. The Standard is a newer product than the Advanced & the Pro.
But don't worry the bats and the charger are the same. I have a Advanced and a Standard.
2015-10-10
DJI-Dave
jellies Posted at 2015-10-10 18:19
I'm coming from 3d helis where I have octopus cables, a huge power supply (two 12v ex-server psus st ...
Yeah I know what you mean. But to add to that I have been flying electric for long enough to remember when we could not charge lipos fast. I remember when we did not even balance them. LOL
2015-10-10
RedHotPoker
Sounds like walking to elementary school, uphill both ways. In the snow with holes in the soles. ;-)
Old fashioned , but had to be done.
I only entered into RC world after the lights were on.
Very grateful for you pionerers and first comers to the hobby.  Who helped us get where we are today, and still progressing.
Perhaps faster in the last few years than the several decades prior.
Happy to be here now. ;-)
RedHotPoker
2015-10-10
