DJI Osmo Pocket 3 Charging slowly
930 7 1-24 07:34
omerfg
Turkey
Hello, I’m using the DJI Osmo Pocket 3. The device has been charging for 7 minutes, and it’s only at 9%. This is the first time I’ve charged it. Is this normal? I’m using a 33W phone charger.
1-24 07:34
hatejittering
It is recommended to use 65W Charger or USB-C charger that supports PD fast charging protocol.
The screen prompts “Fast Charging” when fast charging is triggered, and prompts “Charging” when in normal charging state.
The camera takes approximately 16 minutes to charge up to 80% state of charge (SoC), and around 32 minutes to fully charge*.
1-24 10:58
DJI Natalia
Hi there, thank you for reaching out. DJI Osmo Pocket 3 charges 16 mins to 80%; 32 mins to 100%
Tested in a laboratory environment with the DJI 65W PD charger. Thank you
1-24 11:48
omerfg
Turkey
DJI Natalia Posted at 1-24 11:48
Would charging the Osmo Pocket 3 with my phone's 33W charger cause any issues?
1-24 12:03
Quadcopterer
Flight distance : 786293 ft
No issue, i would buy a quality charger 65w anker or ugreen is both a good choice.
1-24 12:09
DJI Natalia
omerfg Posted at 1-24 12:03
To charge the DJI Osmo Pocket 3, you can use a USB-C charger that supports PD/PPS fast charging protocols. When charging the camera while it is turned off, it will display "Fast Charging." The maximum supported fast charging power is 36W. If you use a non-PD charger, the maximum charging power will be 5V 2A, indicated as "Charging" while the device is powered off.
Please rest assured that using a 33W charger is acceptable, as the maximum supported fast charging power is 36W. However, please note that the charging time may vary when using a 33W charger.
Additionally, you can use a power bank to charge the camera, which allows for charging while in use.
1-24 12:58
omerfg
Turkey
DJI Natalia Posted at 1-24 12:58
Thank you for your answer.
1-24 15:21
DJI Natalia
omerfg Posted at 1-24 15:21
You're very welcome! We're excited to assist you. Your satisfaction is our top priority, so please feel free to reach out with any further questions or requests. We're here to support you every step of the way. Wishing you a fantastic rest of your day.
1-25 01:57
