Standard signal booster
2400 12 2015-10-10
Stan1970
Flight distance : 105318 ft
Hi - Just wondered if there was anyone out there who had tried one of these - TBH I have not had any signal problems as I always stay within sight but wondered if this should be an add on just in case I lose signal somehow - There are lots of people saying they work great on the Advanced and Proffesional
http://www.ebay.co.uk/itm/Antenn ... hash=item1a076330df
2015-10-10
Stan1970
I guess not..........
2015-10-11
sportsfan4393
I bought one similar and it should be here tomorrow. When the weather clears in the next few days I will take it out and let you know my results.
2015-10-20
Stan1970
sportsfan4393 Posted at 2015-10-20 18:24
I bought on similar and it should be here tomorrow. When the weather clears in the next few days I w ...
That would be great thank you - where did you get it from?
2015-10-20
SpunOne69
I have the "Windsurfer" antenna booster (basically the same thing) and it does work.  I went from 1500 ft range to 7500 ft with no video lag or anything.  It isn't omni-directional though, the booster must be pointed perpendicular to the P3P to get good range out of it...   For $30 it was alot cheaper than the DBS or FPVLR mod antennas that are available, they start at around $100 and go up from there, both of those require controller modification as well (for power)...
2015-10-20
sportsfan4393
Stan1970 Posted at 2015-10-20 11:52
You have the P3S correct? That is what I have and will be testing on. I got it from: http://www.ebay.com/itm/26205694 ... =STRK%3AMEBIDX%3AIT
2015-10-20
Stan1970
sportsfan4393 Posted at 2015-10-20 22:49
You have the P3S correct? That is what I have and will be testing on. I got it from: http://www.eb ...
Yes I have the standard so will be interested to learn how you get on and if it works well, I will put in an order!
2015-10-21
sportsfan4393
Stan1970 Posted at 2015-10-21 10:58
Yes I have the standard so will be interested to learn how you get on and if it works well, I will ...
Looks very nice and fits like a glove! Hopefully the weather gets better to test it out!!
2015-10-21
Stan1970
sportsfan4393 Posted at 2015-10-21 20:25
Green my favourite colour ;)
2015-10-21
sportsfan4393
Stan1970 Posted at 2015-10-21 12:35
So the weather today was a bit shaky, but I ended up with a little more than 1800 ft. Longer distance with the windsurfer than without. This was cloudy, windy conditions with quite a few houses around it. I would say it is worth it for sure! Tomorrow is supposed to be a lot nicer out so hopefully I get a better idea of what it is capable of.
2015-10-21
Stan1970
oh well done - this might be a stupid question but does it just boost the RC signal or does it boost the wifi signal as well?
2015-10-22
tdrussell1
Stan1970 Posted at 2015-10-23 01:26
oh well done - this might be a stupid question but does it just boost the RC signal or does it boost ...
The video signal originates from two 2.4ghz directional patch antennae that sit inside the RC.  These are more directional, but overall seem to be a stronger signal than the 5.8ghz control signal from the single aerial antenna.  So to answer your question, no, this does not boost the wifi/video signal, but seems to bring the control signal more up to par with the video signal.
2015-10-23
poutanen.tomi
Flight distance : 437431 ft
Finland
Hi all!   I have made my own from piece of cardboard and aluminium foil and i can tell you, IT WORKS! The farthest I've flown with my P3 Standard was over 2km. That was from the shore over the ocean. Never fly without it. Just adds more reliability when flying and it's very easy DIY! Never thought that the piece of aluminium would give so much more distance and altitude. I've also gone up 500m too, without any signal issues. So i highly recommend everybody the windsurfer antenna mod. And hey it cost me like 2€ (glue)
2015-10-23
