Return Home Height?! HELP!
5956 11 2014-12-17
bymac77
Portugal
Ok, 3rd day flying my P2 vision +... Finally got the guts to fly it over water to film the riverside.
one BIG SCARE about Return Home function when the quod loses radio signal...
I was under the impression then when that happens P2 will go up another 20m (by default) and then hovers home before descending.
I was about 30m when the quod lost radio signal...and it didn't go UP!  It nearly missed a flag pole when returning home... I only realized it when I saw the movie!
Question: when in failsafe mode, will it climb to the altitude of 20m, or does it climb 20m more then the altitude it is at that moment?
Scary failsafe moment here:
River side movie here:
2014-12-17
Gerry1124
If you haven't changed the RTH altitude in your calibration with the PT 2 app n your computer, it will go to 20 meters above the altitude you took off at.  If you were at 30 meters, it will stay there and come home.  You can change that in the PT2 app.  Open the PT2 program on your computer with the Phantom connected and click on ADVANCED, then LIMITS and set the altitude you want the RTH to be at.  Press enter after you change.
You mentioned you were at 30 meters when you lost connection, so you would stay at 30 meters until you arrived at home, assuming you didn't change it in the PT2 app.
2014-12-17
ciprianboboc
Gerry1124 Posted at 2014-12-18 12:37
If you haven't changed the RTH altitude in your calibration with the PT 2 app n your computer, it wi ...
you can change the RTH altitude in settings of vision app on your phone, too.
I have changed my RTH home default altitude to 220 feet. As Gerry said, the RTH altitude is relative to the place where you took off (if the Phantom is already at or over that altitude, it doesn't go higher)
2014-12-17
jarek33
Flight distance : 466696 ft
Called dji for battery replacement told them about me flying on top of the water, he said big no no ur drone will loose Gps and go straight down in water, unless I learn how to fly in manual mode no gps...give them a call see what they say to u
2014-12-17
humboldt710
On the older firmware you could re-set the RTH height in the air with the remote, but now they moved it into the assistant software. Was nice to be able to re-set it above tree height wherever I was flying.
My Hanger
Phantom 2 w/H3-3D gimbal & GoPro Hero3+, 600mw 5.8vtx w/VAS BB Ultra, Large Skids
Phantom 2 w/600tvl, 400mw 1.3 vtx w/VAS BB Ultra, 2.4 Notch Filter, V2 ESC's, MultiStar 2212 Motors, FrSky X6R, Custom Skids
Lumenier QAV250 Carbon on 4S, Cobra 2204/1960 Motors, KISS 18a ESC's, Angled/Extended Mounts, CC3D, FrSky D4R-II, Mobius (almost done!)
Hubsan X4 Stock mini racer, Hubsan X4107D Non FPV(now) racer project, Taranis X9D w/external Antenna & 2200mah lipo, Dominator V2 goggles
2014-12-17
umpa
humboldt710@gma Posted at 2014-12-18 15:24
On the older firmware you could re-set the RTH height in the air with the remote, but now they moved ...
You can still set the RTH height in the mobile app.
2014-12-18
humboldt710
umpa Posted at 2014-12-18 20:18
Yes you can on the P2 Vision. Can only get to it in the assistant software on the P2 Non Vision.
My Hanger
2014-12-18
chuck26287
jarek33@hotmail Posted at 2014-12-18 13:23
Called dji for battery replacement told them about me flying on top of the water, he said big no no  ...
This is interesting.  I thought if you were flying in GPS Mode, and for some reason (just flying over water???) you lost GPS, you would default into Atti Mode, where you could drift, but altitude would still be reasonably maintained (as a result of using the barometric pressure data for altitude, not GPS).  Why would losing GPS over water cause you to go straight down into the water?
Not doubting what you were told, just don't understand it.
2014-12-18
bymac77
Portugal
Atti IS the same as if you loose GPS. I don't know how could they have told you that too :S
2014-12-18
umpa
bymac77@gmail.c Posted at 2014-12-19 11:17
No its not, the phantom still knows where it is and sw1 up will make it stabilised flight and RTH.  It never lost GPS simply did not use it - thats a very big difference.
When you lose GPS yes the phantom will fly in attitude mode - but if the wind takes it - your probably screwed as it really wont know where it is and RTH wont work.
2014-12-19
ciprianboboc
umpa Posted at 2014-12-20 02:03
No its not, the phantom still knows where it is and sw1 up will make it stabilised flight and RTH. ...
So learn to fly ATTI or manual and change your remote to NAZA mode
2014-12-19
umpa
ciprianboboc@gm Posted at 2014-12-20 14:40
Its very important to learn to fly Atti mode for that very reason.
2014-12-19
