Newbie
822 9 2015-10-17
jacksdrone
Hi all! 1st day flying today. The left toggle on remote sticks in pointed down position. Is this normal?
2015-10-17
gongml
Flight distance : 595413 ft
The left one can be locked at down position, but the right one cannot.  If this is what u were wondering...
2015-10-17
jacksdrone
gongml Posted at 2015-10-17 23:04
The left one can be locked at down position, but the right one cannot.  If this is what u were wonde ...
How does one unlock it then?
2015-10-17
jjejfjf
Banned
2015-10-17
Stan1970
Flight distance : 105318 ft
push it back up (forward?) - mine does as well - not so much a  lock but it sticks
2015-10-18
jag01usn
The left switch is a 3 position switch. Sounds like the switch is defective. Should stay in one of the 3 positions you move it too, Left - Center - Right.
2015-10-18
liningiv
Flight distance : 329409 ft
You need to be a bit more specific.
Which "toggle" are you referring to?
Is it the the joystick?  In which case it should be sprung to the centre.
Is it the Switch at the top of the remote?  In which case there is no lock that I am aware of.
2015-10-18
jacksdrone
liningiv Posted at 2015-10-18 09:38
Is it the the joystick?  In ...
Joystick on hand held unit. Sticks when you point downward
2015-10-18
liningiv
Thanks.
None of the controls  should stick.
If you panic for example, you should be able to release both sticks, both sticks will spring to the centre, left to right and up to down, and the P3 should  go into an instant safe hover.
Your controller needs to be replaced for your safety before you lose the drone and or hurt someone.I suggest you dont fly it.
2015-10-18
jacksdrone
liningiv Posted at 2015-10-18 12:25
Thanks.
If you panic for example, you should be able to release  ...
Thank you for your help! Sent back to buydig today-upgraded to advanced with the better controller
2015-10-25
