ciprianboboc
Yes, it doesn't have object detection.
But in theory it could be done by software. While you have GPS, it wouldn't be so difficult to have a customized zone for flying. Assume you go on a map and mark a perimeter to allow flying and then export that data to Phantom.
Sebastian is asking if Phantom could avoid objects based on GPS position and info from a map. That would be way more difficult to implement but not completely impossible.
The better solution is a drone equipped with a detection system based on ultrasound sensors. I wonder if Inspire will have some object detection.
Meanwhile PV+ is blind, and that could be quite a problem for "autonomous" flight mode (e.g. return home) |
