Flight Raptor
Flight distance : 3014675 ft
OK....let me try to answer each of your questions 1by1:
1) 4 batteries....no problem, there are 5 slots (and the 1 inside the quadcopter) so you could technically carry 6
2) Props stay on, no problem
3) IPAD Air 2 should fit in that slot on the left side no problem:
Actual slot size = 270mm (L) x 150mm (H) x 75mm (w)
Case lid = extra 40mm (h)
IPAD Air 2 dimensions = 240mm (L) x 169.5mm (H) x 6.1mm (T)
** IPAD Air 2 will stick above the slot by 19.5mm, but the lid gives you another 40mm of space, so no problem
4) The controller with the ITELITE antenna
- This will NOT fit with the default length of the mount...you must reduce the mount by approx 1" as I did
- The foam in the lit is corrugated (not pluckable) and will not fit the controller and Itelite antenna, even with my mod....you either must remove the foam or cut out a rectangle around the area in the foam that folds on to the contoller/antenna when the lid is closed. The contoller/antenna fit just fine when I completely remove the foam. I ordered another piece of foam from Microraptor pro cases so that I can keep the original one intact (for those times I just wanna use the original controller with no modified antenna) and I will cutout the new one where the itelite antenna is only so that I can shut the lid, still have the foam protection on everything but the controller....I then plan on seeing if a thinner piece of foam can be used in the space I just cutout for the controller/antenna so there is 'some cushion in the lid (maybe 1/8" foam). I'm still waiting to receive my new piece of foam to see how this works out, but should work fine.
5) Foam in the bottom of the case is laser cut (non-pluckable) and the lid is corrugated (non-pluckable). If you would like, however, you COULD choose this exact same case with pluckable foam (I personally like the rigidity of this laser cut foam, but some folks prefer the pluckable....here is a link to that case...it is also cheaper:
Seahorse case with pluckable foam |
