Drift on PAN and TILT
609 1 2015-10-23
Ventuza
Flight distance : 71726 ft
I've seen a few people mentioning DRIFTING on Ronin-M.
I am not so sure I have the same problem, described below:
I do an awesome ballance P/T/R, the motor power is 1 or 0. Actually it is 0 on 2 directions most of the time !
Then I center the camera, with a buble leveler on the flash shoe.
I do a calibrate center.
Then I play with it a bit, no less than 5 min. later the Pan is -3 to -6 degrees off center ( twords left ) and the tilt is -2 -3 degrees ( down ).
I go throhgh the "Calibrate Center" again and 5 min. later same stuff happens.
Using the Remote Controler to bring to center ( MODE: reset to center ) doesn't do anything.
Is it normal that the reset to center won't bring the TILT to 0 ? It fixes the PAN and the ROLL but not the TILT.
Any ideas ?
Thank you !
2015-10-23
DJI-Cathy
The "Calibrate Center" is used to calibrate the PAN axis
2015-10-30
