P3A - replacing camera with new 4K camera, what is involved
1993 6 2015-10-27
info
Hi All,
I've read here (can't find it though), that one can repalce the 1080 camera on a P3A with a 4K camera, resulting in a P3P (minus the 100W charger).
Can anyone point me to instructions on all that needs to be done to do this conversion?
Beyond cables, etc., what about firmware?
This P3A works now (mostly - have not had a lost signal in a while).
I need more pixels, hence the camera upgrade.
thanks in advance for any tips.
2015-10-27
terrylewis
Flight distance : 3517287 ft
You may want to research the following links over on PhantomPilots for confirmation:
http://www.phantompilots.com/thr ... /page-5#post-554764
http://www.phantompilots.com/thr ... /page-2#post-388158
http://www.phantompilots.com/thr ... e-onto-a-p3a.52938/
http://www.phantompilots.com/thr ... .49744/#post-468371
Additional info on removing P3 camera:
Additional info on replacing P3 camera:
Flash with appropriate Pro/Adv firmware depending on camera:
Ensure you understand the risks of diy and all warranty ramifications
2015-10-27
info
Terry,
thank you so much for taking time to share these with me.
2015-10-27
DJI-Tim
DJI Team
terrylewis Posted at 2015-10-28 06:47
http://www.phan ...
Nice and useful video! thanks for sharing, Terry!
2015-10-27
Flyhigh7887
Sweden
let me know how it goes for you.
i plan on doing the same thing very soon. reason behind it for me: so i can try out FPV goggles.
2015-10-28
info
Camera ordered, finally arrived (grr UPS) and now installed
Installed latest P3P firmware and that seemed (emphasis on seemed) to go ok.
Connected ipad to Internet, upgraded firmware on RC as instructed. Not sure how to find out version of FW on RC, anyone?
Now when I reboot everything, the DJI Go app (version 2.1.0) says the aircraft needs upgrading. Why is that? It just got the latest FW.
Can anyone tell me if I did anything wrong, or need to do something else?
UPDATE: after rebooting both craft and RC yet again, no request to update anything appears. The DJI mystery continues....
It is dark and I cannot fly it now. But will try tomorrow if time permits.
Here is contents of the log file from the SD card used to upgrade FW on craft.
[00016815]========== remo-con disconnect. boot(15) ============
[00016923]Firmware [C:\DM368Fw.bin] detected, card sn [0x60ce019b].
[00016954][08 00] Firmware upgrade start...
[00526021][08 00] Firmware upgrade finished successfully.
[00526055]Done.
[00012455]========== remo-con disconnect. boot(15) ============
[00012487]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x28a78402].
[00012521]Packet upgrade start...
[00012564]Packet checking...
[00012601]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012664]Done.
[00012696]Version checking[1]...
[00012770][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012831][03 06][00] v2.2.6.19 -> v2.3.0.13 need upgrade.
[00012871][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00012916][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013006][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013100][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013180][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013266][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013345][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013474][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013556][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013675][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013735][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013767][01 00][00] v1.23.3419 -> v1.23.3419
[00013800][01 01][00] v1.23.3419 -> v1.23.3419
[00013854][08 00][00] v0.12.0.4 -> v0.12.0.4
[00013893]Done.
[00015926]Waiting for user confirm...
[00025957]Timeout, start upgrade automatically.
[00026023]Firmware upgrading[1]...
[00026078][12 00] Firmware upgrade start...
[00092200][12 00] Firmware upgrade finished successfully.
[00092259][12 01] Firmware upgrade start...
[00159624][12 01] Firmware upgrade finished successfully.
[00159677][12 02] Firmware upgrade start...
[00223853][12 02] Firmware upgrade finished successfully.
[00223901][12 03] Firmware upgrade start...
[00292737][12 03] Firmware upgrade finished successfully.
[00292776][11 00] Firmware upgrade start...
[00342246][11 00] Firmware upgrade finished successfully.
[00342536][03 06] Firmware upgrade start...
[00677454][03 06] Firmware upgrade finished successfully.
[00677507][04 00] Firmware upgrade start...
[00735495][04 00] Firmware upgrade finished successfully.
[00735527]Done.
[00735560]Version checking[2]...
[00735613][03 05][00] v34.2.0.9 -> v34.2.0.9
[00735692][03 06][05] v2.3.0.13 -> v2.3.0.13
[00735735][04 00][05] v1.41.0.0 -> v1.41.0.0
[00735782][09 00][00] v1.7.0.3 -> v1.7.0.3
[00735894][11 00][05] v1.7.0.0 -> v1.7.0.0
[00735973][12 00][05] v1.10.0.0 -> v1.10.0.0
[00736047][12 01][05] v1.10.0.0 -> v1.10.0.0
[00736123][12 02][05] v1.10.0.0 -> v1.10.0.0
[00736204][12 03][05] v1.10.0.0 -> v1.10.0.0
[00736367][15 00][00] v1.1.2.0 -> v1.1.2.0
[00736448][17 00][00] v1.1.1.7 -> v1.1.1.7
[00736557][17 01][00] v1.0.2.7 -> v1.0.2.7
[00736602][19 00][00] v1.0.8.96 -> v1.0.8.96
[00736636][01 00][00] v1.23.3419 -> v1.23.3419
[00736668][01 01][00] v1.23.3419 -> v1.23.3419
[00736711][08 00][00] v0.12.0.4 -> v0.12.0.4
[00736750]Packet upgrade finish successfully.
[00012379]========== 2015.11.02 21:20:28. boot(15) ============
[00012410]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x28a78402].
[00012440]Packet upgrade start...
[00012482]Packet checking...
[00012512]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012543]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012573]Done.
[00012604]Version checking[1]...
[00012699][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012769][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012845][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012898][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013015][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013104][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013184][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013260][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013349][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013486][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013559][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013689][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013842][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013875][01 00][00] v1.23.3419 -> v1.23.3419
[00013909][01 01][00] v1.23.3419 -> v1.23.3419
[00013962][08 00][00] v0.12.0.4 -> v0.12.0.4
[00013996]Packet upgrade cancelled at version checking.
[00012411]========== remo-con disconnect. boot(15) ============
[00012445]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x28a78402].
[00012478]Packet upgrade start...
[00012515]Packet checking...
[00012546]Packet vlink 01.04.0010 <-> 01.03.0020.
[00012586]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012621]Done.
[00012655]Version checking[1]...
[00012724][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012783][03 06][00] v2.3.0.13 -> v2.3.0.13
[00012838][04 00][00] v1.41.0.0 -> v1.41.0.0
[00012891][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013183][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013292][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013377][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013457][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013532][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013667][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013749][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013882][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013947][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013980][01 00][00] v1.23.3419 -> v1.23.3419
[00014013][01 01][00] v1.23.3419 -> v1.23.3419
[00014068][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014102]Packet upgrade cancelled at version checking.
2015-11-2
info
Have a P3A I bought directly from DJI. It has been working fine. No lost signal issues like I had with the P3P I returned to dealer.
I wanted more pixels so I bought 4K camera.
Camera was replaced, no issues.
Upgraded firmware to 1.4.10 P3P version, no issues.
First flight after upgrade, no issues. Landed, swapped in battery #2 for another flight.
After about 2 minutes, at a distance of over 1 mile, all camera parameters went to N/A. Then screen went black on my ipad 2.
Screen went on and off the entire time I flew it back to base, having lost the ability to record an image or video (which is the sole reason for spending all this money).
This is exact issue I had with the P3P I bought from B&H and returned to B&H after many. many upgrades, downgrades ,SD cards etc.
SD card for this flight is a Sandisk 64 GB Extreme Pro
sigh.
Replace SD Card with  Lexar 64 GB 633 and return to fly next day.
Two flights with no issues.
Can an SD card cause the screen to black out and the camera parameters to go to N/A?
Is it a temperature thing? Too hot?
I am ready to return this thing to DJI and spend my time on other activities.
Seeing them tout the next gee whiz toys before they have their current gee whiz toy working is more than a little annoying.
Are you listening DJI?
Any ideas?
thanks in advance.
2015-11-8
