Grainy 4k 24fps?
1050 3 2015-10-29
StephLed
Flight distance : 347365 ft
Hey all:
I've been testing my OSMO for the past couple of days and it seems my 4k resolution is grainy - not as sharp and crisp as it should be.  I'm even on the fence with 1080p.  I also own a P3A and film in 2.7k and see a vast difference -- so nothing to do with my Macbook Pro.
Here are the specs I'm using to film:
4k @ 24fps
.MOV format
NTSC (test PAL) as well.
Any ideas?
2015-10-29
BayArea99
Flight distance : 197336 ft
Did you set 60Hz option? Mime came set on 50Hz. Same menu where you set NTSC. Also did you try MP4?
2015-10-29
StephLed
Tested MP4 with no change. I'll try setting to 60Hz. Thanks for the tip-
2015-10-29
DJI-Amy
Can you upload some test videos from the sd card? We need to analyze the original files.
2015-11-23
