sarie
United Arab Emirates
Hi, no it loaded just fine, however, I had another problem that the USB debugging needed to be activated. Which you need to go to about section then the driver area tap it 7 times and this will activate the developers option. In this option you may access the USB debugging mode tap it to activate and you should be able to connect with the USB and the software will load then. However, I am not sure why it is not loading for being not compatible.
I hope this helps in some form.
Regards,
Sarie |
