Hello, this is my first video with the osmo .
This works very well and convenient, but after mounting the film , the picture is sometimes vague.
The cause may be the lens , because there is no sunscreen even on
This video is a good example of the Zenmuse X3 failing to handle image detail when in motion. The compression noise is bad, probably due to in-camera sharpening. A firmware fix is apparently on the way, giving us manual sharpening. So we can set sharpening to '-3' and then add it in post.
here short clips of the first and second time i used my osmo, i am having some issues.. hopefully someone can explain what i am doing wrong.
The first issue is that i am getting Vertial Lines in everything that is over exposed.. It is Not the exposure warning, it still in the footage after i bring it to my computer and does not go away in Post. I tried i bunch of different setting and exposures, ISO and it the lines remain
The Second Issue is that I am getting a White flickering Noise pixles and random times, it might be becase of under exposed, but i am not sure.
Hi, can you send the problem photos and videos in the SD card to me ? I will analyze the problem and contact you as soon as possible. My email address is 2881006500@qq.com .
