DJI launches new Manifold embedded computer for aerial platform developers
8117 12 2015-11-2
DJI-Delphine
MANIFOLD
The Manifold is a high-performance embedded computer specially designed for the DJI Onboard SDK. It enables developers to transform aerial platforms into truly intelligent flying robots that canperform complex computing tasks and advanced image processing literally on the fly.
Powerful Computing on theFly
With the NVIDIA Tegra K1's 4-Plus-1 Quad-core ARM Cortex-A15 Processor and 192 GPU CUDA cores with clock speeds of up to 2.2GHz, the Manifold allows you to take off with the world's most advanced mobile processors. The GPU cores provide powerful image processing abilities,efficient parallel computing, and a blazing fast throughput of 326 GFLOPS. Now you can design more intelligent applications that unlock the full potential ofyour aerial platforms in whole new ways.
Advanced Image Processing in the Sky
The Manifold packs the processing power of a PC graphics card and supports DirectX and OpenGL, enabling your aerial platform to process high resolution images in real time. It can be deployed for use in artificial intelligence applications such as computer vision and deep learning. This means your aerial platforms will not only be able to sense the surrounding environment, but also identify objects and respond in an instant.
Convenient Development Environment
Designed for developers, the Manifold's built-inUbuntu operating system supports CUDA, OpenCV and ROS. It is ideal for researchand development of professional applications. The Manifold can natively run the DJI Onboard SDK, access flight data and perform intelligent control and data analysis. With CUDA, the Manifold can be used to accelerate your applications to achieve unprecedented levels of performance.
Low Power Consumption
The Manifold is optimized for power efficiency with a peak power consumption of approximately 15 W, or one fourth of that of a typical laptop. The Manifold's Tegra CPU uses four A15 cores for heavy computing tasks while, and a single battery-savercore when performing simple calculations. The number of active cores can be dynamically adjusted to decrease power consumption, and the extra core will automatically be activated when needed.
Comprehensive Connectivity
Equipped with USB, Ethernet, Mini-PCIe, HDMI,UART, SPI and I2C ports, the Manifold allows you to connect to a wide array ofsensors, monitors and other peripheral devices. The Manifold also provides customized ports to connect to the Matrice 100 and process the images capturedby the camera mounted to the platform.
2015-11-2
Airflix
Flight distance : 173622 ft
Shut up and take my money!
2015-11-2
rodger
Flight distance : 20145135 ft
Another addition to the ever-growing DJI line of products.
2015-11-2
RedHotPoker
Flight distance : 165105 ft
They own the forum and sell us the awesome. . .
Welcome to the @DJI Forums.
Please Make all cheque/s payable to. . .  ;-)
RedHotPoker
2015-11-2
Michael M
Flight distance : 1984898 ft
Powerful Computing on the Fly- literally
2015-11-2
mariano76
Flight distance : 509196 ft
Michael M Posted at 2015-11-3 03:28
AHahah
2015-11-3
Citation
Flight distance : 134908 ft
I'll take two please.
2015-11-3
curaga
What are the differences between “Manifold” and the “Erle-Brain 2” platform??
I can see the price for Manifold is 500$ where the Erle Brain 2 seems to have same capabilities and objective for 199€ (217$), actually this product not only allows to use Snappy Ubuntu Core but also Debian file system which might interesting to have for some developments.
The ports and connectivity I see are exactly the same (CAN, UART, HDMI, USB, Ethernet…) and also runs a CPU with a Cortex-A7 processor (which I guess is more than enough for the drone use cases)..
I am really happy to see new solutions for drones (these platforms finally make REAL smart drones) and test what I can do with them, but still asking why is the difference so big between these two platforms from 217$ to 500$??
I also found this in some other blogs..
2015-11-4
curaga
I have also found this on the blogs..
2015-11-4
jblack22785
Please forgive my ignorance - but what is this?  I feel like an old man who just opened the internet for the first time ...
What is (1) real-world example of what I would do with this?  (other than the clearly smart ass answer of "for me ... nothing").
2015-11-6
Phuglie
Flight distance : 45226 ft
Aren't there separate forums for SDK users? Why is this posted here???
2015-11-9
vonbaron1
Flight distance : 42014 ft
Phuglie,   Well stated.
2015-11-10
mariano76
vonbaron1 Posted at 2015-11-11 00:46
Can manifold be adapted to Phantom 3?
2015-11-11
