Has anyone tested what would happen if you turned off the RC?
978 6 2015-11-3
JapanDave
Japan
Just curious if anyone has turned off the RC mid flight? And as to what would happen if all power was to fail the RC and how the bird would reacte?
2015-11-3
jimhare
Flight distance : 239035 ft
I haven't tried it but the bird should hold it's position for a few seconds and when it decides the signal isn't coming back it should return to home.
2015-11-3
GeneralToner
Done it.  It's just a RTH situation. No worries if remote dies and you check RTH info before each flight.   I wanted to see what happens and figure better in a safe place (normal testing location) vs out shooting where don't know area as well.
2015-11-3
jlivingston6
Flight distance : 82556 ft
I have tried it after installing the latest firmware. If you have set your
RTH at a good height to clear everything then it will return home after
A little bit as it goes through the RTH procedures. Mine worked right.
2015-11-3
GB44
Flight distance : 343848 ft
I have tried this in the past as part of a commercial UAV Pilot examination when you are required to demonstrate the safety features of the aircraft.  Works perfectly, return to home initiated.
2015-11-3
JapanDave
Japan
Thanks. Just have to wonder why these birds that get no-signal drop out of the sky???
2015-11-3
doctrrf
JapanDave Posted at 2015-11-3 16:04
I have recently needed to turn off the RC while testing a third party app, sure enough, the bird returned safely home.
Most reports of birds "dropping out the sky" translates to: operator error. (In my opinion)
2015-11-4
