FatShark Dominator V3
1303 6 2015-11-3
BASS 666
hi guys .. anyone using the above ? need a bit of info as im looking to buy a set ....
2015-11-3
Mad_Angler1
Flight distance : 2741657 ft
yes i do, i have Headplay as well
What you want to know
2015-11-3
BASS 666
Mad_Angler1 Posted at 2015-11-3 23:55
thanks mate .... are the v3s a good job and what receiver and antenna do I need ? do you have a link for antenna and receiver ? iv looked at receivers 2.4 ghz but I read somewhere you don't use 2.4 which is wrong I think ? my tablet crashes every ten mins when I use it .. will the goggles be the same or is hdmi out to the goggles better ? thanks for the answers in advance ....
2015-11-3
BASS 666
right I just found out I don't need a receiver or antenna because its wired to the HDMI module .... can I set the phantom up with the tablet and then disconnect the tablet and just use the goggles ?
2015-11-4
Mad_Angler1
BASS 666 Posted at 2015-11-4 12:52
right I just found out I don't need a receiver or antenna because its wired to the HDMI module ....  ...
yes sorry for the late reply,
yes you can fly with just the goggle or with both
Have a read of my Dom Vs the HP here
http://www.rcgroups.com/forums/showthread.php?t=2503097
2015-11-4
BASS 666
Mad_Angler1 Posted at 2015-11-4 18:23
thanks I will have a look .... what settings do you use ? iv just installed the HDMI board and there are 3 settings .. 50 or 60 hz ? osd one I know what that means ... output to app and hdmi ? if I leave it on it outputs to both and if its off its just the hdmi ?
thanks for helping me out ....
just ordered the v3s as well ..
do you know how to find the RCs firmware so as I can check it has changed when I installed the new board ?
2015-11-4
BASS 666
I found the rc firmware when I updated to dgi go .... as for the rest of the questions I will find out for myself when I get my goggles tomorrow ....
2015-11-6
