Dji lightbridge no osd
5256 28 2014-9-23
papo3r
Flight distance : 496962 ft
Hi got a f550 with a2 controller lightbridge and h3 3d gimbal For video a samsung note pro 12.2 video works fine but no osd video 100% but others 0% Any help
2014-9-23
Blade_Strike
Flight distance : 872694 ft
Make sure your canbus is connected.
2014-9-24
papo3r
Thanks blade yes the can plug is connected.As I know the app decodes the osd.If the samsung note pro 12.2 isn't in the list it won't work.How can I make it work. If it's possible.
2014-9-24
Tahoe_Ed
Flight distance : 2605 ft
But is it connected to Can 1?  That is the difference.  The app does not decode the osd the ground unit does.  I can turn on my ground unit without connection to the air unit and see the osd overlay.  If you cannot see it then, what version of the android os are you using and is debug enabled?
2014-9-24
papo3r
Puerto Rico
Yes its connected to can 1.The app is kitkat 4.4.2. I can see osd but the only one is video with 100% signal Radio,Satellite,Distance Alt etc. are all 0%.
2014-9-24
Tahoe_Ed
papo3r Posted at 2014-9-25 07:22
Yes its connected to can 1.The app is kitkat 4.4.2. I can see osd but the only one is video with 100 ...
The video and RC signal strength are reversed.  You have RC but no video.  Please check the connection between your camera and the air unit.  Is the camera led solid green?
2014-9-24
papo3r
Yes they are green.And I can see osd on screen .The problem is all are reading 0% except video that reads 100%.
2014-9-25
Octocott
Flight distance : 668694 ft
Belarus
Same for me!
LB connected to CAN BUS hub and it's all "0" and does not react on GPS mode change.
Control and video are fine.
2014-11-20
Blade_Strike
Octocott
Can you please post current firmware of Lightbridge on both air and ground., what controller you're using and version of app, please?
2014-11-20
contact
Octocott Posted at 2014-11-21 02:24
Same for me!
Con ...
Same for us
we have 2 lightbridge systems, one with nazav2 phantom2 and it works fine, one with A2 and all"0" .....
2014-11-21
Blade_Strike
You are connected to can 1, correct?
2014-11-21
Octocott
Belarus
Correct for me. LB, IMU and GPS go to CAN-BUS Hub and to A2 CAN-BUS port 1 LED and PMU to A2 CAN-BUS port 2
My firmware on all units is all up to date. Tried on iOS (8.1) and Android latest apps. No good.
Radio is Futaba F8J (TX turned off as instructed in the manual)
2014-11-21
Blade_Strike
Do you have the camera outputting video? I know that I won't start receiving osd data via the app until a valid video signal is received.
2014-11-21
Octocott
Belarus
Yes it does. A GoPro With the cable supplied.
2014-11-24
papo3r
Hi octocott I think that our problem it's the app or the phone. What phone you are using .Im using a samsung note pro 12.2
2014-11-24
Blade_Strike
I would have to agree.. As longs ALL firmware is update on the Lightbridge and FC.
2014-11-24
Octocott
Belarus
Iphone 5s, Galaxy Gear
2014-11-29
papo3r
Hi octocott you said you got two system one naza v2 and one a2 works but the other don't .On both you have tried the same phone with the same app.
2014-12-1
papo3r
2014-12-3
papo3r
That's what I'm trying to explain
2014-12-3
sandberg1976
Sweden
Greetings. I got my Lb and have been trying to get everything working as many other.. BUT. I use A2, Z15, Gh4 gimbal and Futaba t14sg. So i connected everything as should. However, it should go on Dbus right, but when i switch it to dbus everything goes down.. Some channels do work but not everything as i putt them before.. And now, cant get them back.. I did get before tilt and roll and so to work but not on those channels as i want.. And the Shutter dont work at all no matter how i try.. Can some help me please.. ?? Sitting two days now..
2014-12-3
shawn
sandberg1976@ho Posted at 2014-12-3 22:21
Greetings. I got my Lb and have been trying to get everything working as many other.. BUT. I use A2, ...
First plug up the LB ground unit to your computer and calibrate your sticks through that. Once you have everything correct in LB connect your A2 to your computer and calibrate your sticks once again in the A2 assistant.
2014-12-3
Blade_Strike
And remember  everything will run over canbus so no need to have any of the F ports connected. Just make sure the gimbal cable is connected to the LB and gcu.
2014-12-3
kindskopf21
Hi Guys,
i had the same issue and was searching for Days... for me ist was a faulty hdmi cable between Gopro and Lightbridge... if you dont have a propper Video, somwhow the Lightbridge doesn't send a propper OSD Signal, just the Image Signal is shown then. Solved for me :-)
2015-1-14
rafael
Brazil
Question,
Is possible to see attitude line (artificial horizon) and homepoint on Screen, like Mini iOsd?
2015-1-17
emanuelevacca
Same problem here:video quality is shown but osd data not available.
But i don't have a connected camera. I read here that osd doesn't appear if no video source is connected.
I will try with a camera as soon as it will arrive.
2015-4-18
harry.wilson
Did you ever resolve this issue? I'm having exactly the same problem. I think it might be because the lightbridge isn't connected to the CAN 1 port on the A2 however I cant see how to wire it up properly.
2016-5-23
xtin_mania
Indonesia
Do this peoblem have any solution? I,m having the same problem here. And my failsafe wont work either. I turn off my groung PB it wont change to failsafe mode. Please and DJI admin give a real answer not a guess we are all customer and have soent a lot of mobey to your products.
2016-10-2
DJI-Jamie
Flight distance : 112405 ft
xtin_mania Posted at 2016-10-3 06:38
Do this peoblem have any solution? I,m having the same problem here. And my failsafe wont work eithe ...
Can you please provide a list of your set up and whether this is your first time setting this rig up or when you started to notice this problem?
2016-10-3
