Matrice veers off to the right after take off?
708 1 2015-11-7
rittim
Hey guys,
Recently just got a matrice with guidance. Both battery and guidance are mounted below the machine but as soon as I apply power to the matrice it immedietly starts to veer backwards and towards the right?
Does anyone have any idea as to why this is happening? I've tried switching off guidance and trying it to no avail though.
Any help would be appreciated :-)
2015-11-7
DJI-Amy
Hi, please try the following methods:
1) Try to remove the guidance and test again. If the problem solved, then it's the problem of the Guidance.
2) Try to check whether the sensors of guidance was blocked or not.
3)If the problem still persist after you detach the guidance, please try to calibrate IMU after power on and test again.
4) Try to use auto take off.
2016-1-7
