nigelbrinkmann
Flight distance : 586391 ft
I do calibrate the gimbal every time before using the osmo,dosn't make much of a difference, but what i did find is, if you twist your wrist back and forth just after starting the osmo then operate the gimbal with your thumb stick pan left and right then bring it back to the center manually, it seems to be ok, I only do this when I want to do a time-lapse, stops the gimbal moving and jumping around while its taking the time-lapse pic's,
I also get horizon tilt , I can't seem to fix this (except to manually correct it) ,Mostly happens when its mounted in the car, after turning a corner, and it dose level out eventually, hopefully the next FW update will help these issues? |
