Camera settings
620 1 2015-11-9
tom.drake
Hi guys,
Im using a 5D mark III with 24-105 IS. It looks like the footage has rolling shutter on it, what is the ideal settings to get a smooth image? My current settings are 25fps, 50 shutter. I'm guessing the shutter should be on 100 or above?
Thanks in advance.
Best,
Tom
2015-11-9
NiklasHFN
Your Shutterspeed should be the double of your frame rate to create a natural look.
But if you are doing fast movements with your camera it maybe would be smarter if you put your shutter speed higher then 1/50. Just try out what look suits you the most.
It would be also smart to use a higher framerate. With Magic Lantern and the 5D III it is possible to record in RAW at 1920 x 540 at 50fps and you can stretch the 540 to 1080 in post.
Or you just shoot at 720p at 60fps at 1/130.
I hope I was able to help you a bit.
with kind regards
Niklas
P.S. There are amazing videos on youtube which show you, how to use your shutterspeed to create different video styles, etc.
2015-11-9
