Rincewind
Taiwan
Hi Roi,
I've had something similar happen to me, but at the same time, I got relatively high differences in the voltage between the first, and the other three cells (~0.05 to 0.07v difference). My battery life went down to 91% at a given point. Now, after seeking advice here, what I did to improve the cell differences was perform five charge-discharge cycles going from 100% to 30%. That helped a lot, and now healthydrones says that I have minor differences with one or two major ones, which I have been told is ok. As for the battery life, it looks like the sensors in the smart battery need to get re-calibrated after a while, hence the recommendation to go to down to 8% every 20 cycles. After doing that and IMMEDIATELY charging, my battery went from 91% battery life to 99%, which I would say is quite acceptable after around 50 cycles.
I hope this helps |
