Hi AK Eagle!
Pick and pluck foam tends to be less durable than foam withpre-cut cavities. I work for CasePro and we offer cases with high-density foamspecifically designed for the Phantom 3, so they offer better protection andsecurity than pick and pluck foam. Thesecases can fit all three Phantom 3 models (standard, advanced, and pro) withouthaving to take the propellers off.
It features our new RecoCell foam for added cushion andprotection. Like memory foam, RecoCell foam shapes itself around your Phantom3, creating an ultra-snug fit without damaging the drone at all.
The wheeled version can be checked into the baggagecompartment of a plane, but don't worry! The heavy-duty exterior and highdensity foam interior will keep your Phantom 3 protected no matter how roughlyit is handled.
You can also customize the foam interiors on these cases tocustom-fit any other accessories you want to carry in the case as well. No needto cut through foam that isn't right for you! Just click the orange "AddCustom Foam" button on the pages above and use our online customizationtool to build a foam interior that is perfect for your needs.
All three cases I linked above are waterproof, in additionto many other features you can see on the pages above.
