Geebax
![](https://forum44.djicdn.com/data/attachment/common/4e/common_26_usergroup_icon.png) Captain
I can't say, as I put the 4K footage through Resolve first to colour correct it and downscale to 1080p. Then I edit the result in Vegas Pro 13.
But the very fact that it is 60 mb/s is a clue, that means it is more highly compressed than say a 100 mb/s file, and a higher compression means more work for the decoder and render engine. I am guessing that DJI use a high compression algorithm to make the result less dependant upon the write speed of the SD card. This means we can get away with using lower cost SD cards.
Blackmagic, for example, have to specify a very high spec card because the write rate for their RAW files is much greater, and only one make of card reliably does the job. |
