dronetofly
Serbia
Hello,
I Have a problem with DJi F550 with Naza V2, Zenmuse h3-3d and Dt7 & DR16 system.
When I connect battery on Dji f550, everything is good. I fly about 2 minutes and landed. Disconnected battery from power.
After 5 minutes I connect battery again, and LED module constantly blinking red light.
I disconnect battery and connect it again, but problem shows again. I reconnect battery several time and
on 3rd connect LED blinking ok (good), but gimbal won't start, I disconnect battery, and connect again, then LED
again blinking bad (constantly red). After 10 times of disconnecting and connecting battery to power of Dji F550,
LED blinking ok and I will go to fly. F550 fly good after that.
When problems shows up again (after about 10 -15 flights) I connect LED module via USB to Naza Assistant and Assistant show Error 29 (Motors Start failure caused by TV stick(s) mid point error to big...
I calibrated sticks and do it like manual says, but after some time problems come back.
Can anybody know what the problem is and how to fix it?
Best regards
