FC40 HELP
1411 3 2014-12-23
adama147
Hi all,
Purchased a FC40 (1 month old) from a friend of a friend. The drone is in great condition and was packaged back up like new when i recieved it.
Out of the bottom of the body you have the lead that connects to the magnetic compass and the two phial sensors. With one of the phial sensors comes a red and grey tiny cable with nothing on the end. Just wondering what this cable is used for? Should it be like this?
I can't see what its connected to without opening body up. Just wondered if this is a common occurance.
Thanks
Adam
2014-12-23
jamesnns
The two antenna wires are gray. Up inside the cavity are one red and one gray. This is normal. I believe they are extra leads to the board. One post one ground. I just pushed them back inside.
2014-12-24
adama147
Cheers for your help, this clears my query up!
2014-12-24
Jbrenli.email
Norway
Hi! These extra cables is for an external battery. You can mount a XT60(I think the name is, can't remember), and use an extra battery.
You MUST use 3S 11.1v battery on this as well. As DJI says, it's for the "DIY's" :-)
2015-1-22
