Hello. I upgraded to the latest version of the app and RC and I'm getting a NO SIGNAL, no picture error on my DJI Go app. It just happened all of a sudden one day. I can still control the Phantom 3, it can hover, I can control the camera, I can even take out the SD card and view the photo on my computer. But there is nothing, just a blank screen in the app. I've tried updating the firmware in the RC again and it appears to upgrade successfully but still not working.
I've just received back my p3a from repair center in Germany, I reported through RMA form the NO SIGNAL issue but I've tried with repaired drone and still having the same issue
The problem is nothing of all that ,, in service they know NOTHING
The problem is that you Upgrade the TX firmware to 1.4.3 you must go back to 1.3 Firm to your TXI try to find the way to downgrade GL300A to previus firmw
I am having same issue, out of the blue. Reinstalled GO app, no change, checked airplane mode, ok.
Ive had 3 to 4 flights on newly updated software.Did you reload 1.3 version and find the problem was resolved, as you did not mention how to revert to older software or if it worked ?
Try another SD card.
Some on the Phantompilots say to drop your resolution to 1080p @ 30fps and this will restore the FPV. It's theorised that the high 4k/2.7K resolution recording could be chewing up some processing speeds or bottlenecking from write speeds to buffer/SD cards on the P3 end.
Also, try selecting custom channel with 4mbs transmission speeds.
And finally, maybe check your debugging modes - disable it, restart phone, and then re-enable it.
