stream videos shot with drone to smart tv
2218 7 2015-11-16
pcocherell
Flight distance : 91814 ft
Okay, usually I am pretty good at this stuff. I have a computer and I have a couple Samsung smart tv's. I play or stream videos all the time from my computer to the two tv's. After flying the phantom I like to immediately transfer video to computer. Then stream the flight video to smart tv. However, I am no longer able to stream videos to the tv's. Every other video works fine. I save using the .mp4 format. I tried .mov and that does not work either. However other .mov and .mp4 files stream fine. It is only videos shot with the drone. Any ideas?
Dell computer with windows 10
phantom 3 advanced
2015-11-16
DJI-Patrick
Hi pcocherell , have you noticed the resolution of your files ?  It could be a compatibility problem .
2015-11-16
sdharris
Flight distance : 384967 ft
Yes, perhaps try in a different format and lower the resolution as your TVs or Windows 10 may not be able to stream that particular file format or resolution.
2015-11-17
fredlaw
Flight distance : 486155 ft
Use plex server works great all formats
2015-11-17
SpunOne69
4K might be the problem...try 1080p
2015-11-17
Kneepuck
Flight distance : 275105 ft
All of the above.  Because it is a smart HDTV does not mean it can play a 4k video file.
2015-11-17
Goggles Pisano
Flight distance : 8810745 ft
Being you have an Advanced you cant have 4k videos You probably recorded at 2.7k that can be your problem. Record at 1080 and  mp4 if you want to view on you Sam Slong..  That should work...
Goggles
2015-11-17
pcocherell
Yes, being that it is advanced it does not record at 4k.  It does not stream 2.7k drone videos, 1080 or even 720. It used to be able to just fine though.
2015-11-18
