jrm11
Flight distance : 224577 ft
Yeah, I know I need ND filters. Just having trouble figuring out which ones to get. I definitely want to be able to go to 16 or 32, which doesn't leave much choice. The Polar Pro, for example, only has those in the larger, more expensive pack.
Adding to my confusion is the lens hood issue. Going with a screw on filter, I am not sure if
1) the lens hood will work with the filter
2) the weight of hood + filter is too much for the gimbal,
So that's what I am trying to figure out. Which filters will work best with which lens hood and not over-stress the gimbal when used together.
It may be an obvious question to those who have one or both of these. From the photos I had seen of filters and lens hoods, it is not clear how they attach and if they will work together. Also, some filters suggest the use of counter-weights, which makes me concerned about weight on the gimbal.
