DJI-Dave
Pilot skills:
practice following a line or something on the ground in visual mode and also try FPV. Do oval flights in both directions, after flying up high to practice try flights as close to the ground as you are comfortable, nose in around yourself, nose out around yourself, circle nose in on a tree, lots of camera manipulation both still and video. I try to exercise all the elements of the DJI Pilot App Now called the Go App: using the map, camera controls, etc. One of the biggest is using the map and the FPV aspect to get a better handle on spacial relationships on how far you are and how close you are to an object using the FPV and Map. Hope that helps.
