Its a problem that has progressivly getting wross, I was having the wiggle the micro HDMI to get the video signal to work sometimes. After configuring a new T14SG and panel antenna's with etentions my video feed is there but very intermeittant and unusable. bad picture, split in two and no color. Video LED on Air unit flickers red and green.
I think that its un related to the upgrades. ( I have swapped back to the normal short anntenna's to prove that )
I have read somewhere that people a changing out the micro HDMI cable for one they make for the BMPCC becuase it's stronger? I havnt been able find this mention again since tho. pretty typicle.
In the mean time i have ordered a new cable.
I have checked the connection inside the zenmuse, insured it was connected and refitted some tape to make sure it will stay in place.
The BMPCC HDMI cable can not be used on 5N, if the video led of LB air end is red sometime, it may be the HDMI cable, board or LB air end, once you get the new cable, you can give a try
I have purchased a new board and a new cable and it has not fixed the problem. I am getting a red light now on the light bridge air unit and nothing on my iPad at all....
