OSMO Horrible Handling
1332 12 2015-11-25
victormikhalchu
Greetings,
I finally received my OSMO gimball and was excited to use it. After just one use, the gimbal began to loose connection, add unnecessary shake, and now it has added an extreme "jello" effect to my footage. At first I thought it was my app, but it appears that something is definitely wrong with the gimbal. Does anyone experience the same problem? Here is the link to the video where you can see this "jello" effect in action () /// password osmo1. But then things got even worse. After doing the latest update, where it restores the system to its default, the gimball stopped working altogether... I've contacted the support team, no response yet.
Need help,
Thanks!
2015-11-25
sploodge
Flight distance : 809350 ft
WOW not seen the Osmo have jello before, that looks worse than anything I have even seen on the Phantom quadcopters..
I would hope a DJI Rep might chime in for you soon.. Worth noting that the US/LA office have issued a note that they are off until the 30th for thanksgiving ( http://www.rcgroups.com/forums/s ... amp;postcount=43989 ).. But other DJI reps on here should get back soon..
2015-11-25
dlongcamp
Flight distance : 755988 ft
That is crazy.  Are you sure you have the camera locked down.  It appears like its loose from the handle.
2015-11-25
victormikhalchu
dlongcamp@aol.c Posted at 2015-11-26 04:55
That is crazy.  Are you sure you have the camera locked down.  It appears like its loose from the ha ...
No, everything is connected and fully unlocked. Out of 20 shots that I took on that location, 14 ended up having that problem. Pretty bad! Hoping to hear from DJI soon.
2015-11-25
Skyrider
Banned
2015-11-25
DJI-Amy
Hi, try to remount the gimbal and make sure you've locked the gimbal lock ring. If the problem persists, it might be the hardware issue. Can you provide your contact email? I will report to the US support and let them contact you as soon as possible. Thanks.
2015-11-25
daniel.huang
Flight distance : 233 ft
Hi, have you noticed any visible vibrations on the camera/gimbal axis?
2015-11-25
victormikhalchu
daniel.huang@dj Posted at 2015-11-26 11:30
There was some minor vibration when this jello effect took place.
2015-11-25
daniel.huang
victormikhalchu Posted at 2015-11-26 15:08
Seems like the problem.
What's your email account when contacting DJI NA? You might need to wait until next week and arrange the return of your OsmO.
Sorry for the inconvenience.
2015-11-26
victormikhalchu
daniel.huang@dj Posted at 2015-11-27 10:24
What's your email account when contacting DJI NA? You might need to wait  ...
Ok,
I've reached out to them through esvideography@yahoo.com
2015-11-27
victormikhalchu
DJI-Amy Posted at 2015-11-26 09:51
Hi, try to remount the gimbal and make sure you've locked the gimbal lock ring. If the problem persi ...
2015-11-27
DJI-Amy
Thanks for the reply, we will let the US office contact you as soon as possible.
2015-11-29
victormikhalchu
DJI-Amy Posted at 2015-11-30 14:16
Please do,
Thanks!
2015-11-30
