Follow Me
641 6 2015-11-26
donald.goodwin
Flight distance : 17687 ft
I have used the POI with ease and success. When I try to use follow me I keep getting the GPS signal is to weak yet, I have at least 17 connections with satellites. Would like to know if there is something I'm missing. I follow the instructions. The App says GPS signal is good.
2015-11-26
Rebel
Banned
2015-11-26
DJI-Patrick
Hi ,donald
May i know what device are you using ? If you are using a tablet , please confirm that tablet contains a GPS unit .
2015-11-26
Geebax
If you are counting the satellites on the display, those are the ones that the aircraft is seeing. In order to use 'Follow Me', the device you are using, phone or tablet, must have a working GPS receiver and be able to clearly see the satellites as well. It is the device's position the message about weak signal is referring to, not the aircraft.
2015-11-26
donald.goodwin
DJI-Patrick Posted at 2015-11-27 00:29
Hi ,donald
May i know what device are you using ? If you are using a tablet , please confirm that ta ...
Thanks, That explains it.
2015-11-27
donald.goodwin
Geebax Posted at 2015-11-27 00:42
If you are counting the satellites on the display, those are the ones that the aircraft is seeing. I ...
Rhanks. That explains it.
2015-11-27
DJI-Patrick
Enjoy your flight !
2015-11-29
