Radio Channel Quality Poor?
1332 4 2015-11-29
bender.d
Banned
2015-11-29
Geebax
This issue comes up quite regularly, the message is talking about the overall quality of the radio link, and it is not necessarily a fault, nor is it a software/firmware issue.
The radio channels the Phantom uses are shared with a number of other services in the radio spectrum, most notably WiFi, and if there is a lot of activity in your region then the Phantom control system will try to switch to another channel to avoid conflict. If it cannot find a channel that is free, it will alert you to this fact by bringing up this message.
The most common solution to this is to try flying somewhere else where there is less interference.
2015-11-29
mtnmaddman
I have  had that also,  I suggest that you uninstall the app using your settings menu and clicking  on the app then uninstall, then go in using a file handler and delete the dji folder.  then reload app.  Also turn on airplane mode and wifi off.
2015-11-29
quanthonytrang
Flight distance : 419980 ft
Tip: The post by the administrator or moderators shield
2015-11-29
DJI-Patrick
Hi, Bender
Please take care of your flight space and your attenna orientation .
2015-11-30
