Flight underneath HomePoint
683 4 2015-11-30
JK JK
Flight distance : 652552 ft
Czechia
Instead two questions I have made this picture.
2015-11-30
gil
Flight distance : 1379308 ft
It will simply show the altitude with a minus sign.  As far as using the Auto-Land in that condition, follow what the manual says:
2015-11-30
johnsr
Flight distance : 1579022 ft
gil Posted at 2015-11-30 14:22
It will simply show the altitude with a minus sign.  As far as using the Auto-Land in that condition ...
Yes a negative altitude.
A similar question which each of us has asked before flying the first time from a bridge or a cliff is “what happens when I hit RTH?” If you have not set a new Homepoint after takeoff, the Phantom will rise to the RTH altitude (above the homepoint “0”) and return. So beware when under a bridge. Another point, if you’re exploring a narrow canyon, you might lose satellites and pass on P-Atti mode. Last, I personally find it difficult to judge relative heights of the bird and obstacles when they are well below. Have fun!
2015-11-30
DJI-Patrick
Hi ,
In this case , the altitude should be shown -10 m in the APP . And don't worry about the auto landing , it would not  drop at 0 m .
2015-12-1
JK JK
Czechia
Take it. Thank you to all
2015-12-2
