adjusting sensitivity of control sticks
10096 9 2015-12-1
milbear
Is there a way to adjust the sensitivity of the control sticks?  I hope you understand what I mean.
2015-12-1
DJI-Patrick
Hi ,Milbear
Please click the icon near the Homepage .And you'll find a "Gain& Expo Tuning" in the "Mc Settings" . Get into the "Gain& Expo Tuning" and you'll find what you need .
2015-12-1
jag01usn
After looking at pictures on line in side the RC there are screw adjustment to change the spring tension on the control sticks also. To do that one would half to remove the back of the RC. DJI should have made direct hole placement over the adjusting screws for each control stick to change the tension and feel for each control stick. Most good RC transmitters allow one to change that spring tension.
2015-12-2
milbear
Thank you . I'll look into both suggestions ....
2015-12-2
pi-inthesky
Flight distance : 13058 ft
milbear Posted at 2015-12-2 12:50
Stick with the app gain & expo settings thats why their there.Messing around inside the rc not practicle
2015-12-2
jasper7821
Flight distance : 1515312 ft
If you want to slow the inputs down, in that Gain and Expo Tuning screen just swipe your finger from the middle of each box to the bottom right and it will go to .20 or just enter .020 in each box.
That's as mellow as the craft can be.
Also, you can slow the braking down by scrolling the menu further down. Then it won't stop so sudden when you let go of the sticks.
2015-12-2
HermosaDrones
Flight distance : 3160344 ft
make sure you write down settings before changing them in case you want to go back to them later.
2015-12-2
HermosaDrones
2015-12-2
djiuser_mM8SVAT5NJa5
DJI-Patrick Posted at 2015-12-1 23:29
Hi ,Milbear
Can you be more specific where to find this setting?   I have a Phantom4 Pro+ V2.0 and I'm looking to soften my stick settings to slow / smooth them
2019-1-4
Cetacean
Flight distance : 2528264 ft
djiuser_mM8SVAT5NJa5 Posted at 1-4 11:09
Aloha mM8SVAT5NJa5,
     After you have started up your system, go into the DJI GO 4 app "Live View" (Camera View).  In the upper right corner is a three lines icon.  Tap it.  This will bring up the "General Settings".  In the left column at the top is an Icon that looks like a quadcopter, tap that icon to get to the "Main Controller" settings.
     In the "Controller" settings, go all the way to the bottom and tap "Advanced Settings".  Look for "Gain & EXPO Tuning".  Select EXP.  EXP will look like three graphs with a number below each one.  Tapping the number will bring up a "Key Pad" so you can enter a number that will allow you to change the sensitivity of the stick for each of the three types of movement.  (You can also use your finger to manually move the graph line to a curve you like but be sure to test it to see if you like the result.)
     YAW is going to be the most important setting (middle graph) and putting it at 0.20 or 0.25 will give you a nice curve for good control (the same curve works well on the other two).  Remember that you can also make changes for the "Sport" Mode setting - choose the same one (0.20-0.25).  Just flip the toggle on the upper left side of the top of the controller between Sport (S) and "P" Mode.
     It will also help you a lot if you review or read the P4 Pro Manual (the link is below).
https://dl.djicdn.com/downloads/ ... _User_Manual_EN.pdf
Most of us helping others on the Forum here have read the manual many times.
     It will also help you a lot if you review or read the DJI GO 4 Online Manual (the link is below).
https://forum.dji.com/forum.php?mod=viewthread&tid=118397
     Hope this helps!
     If you have more questions, you may want to start a new thread.  This thread is three years old.
Aloha and Drone On!
2019-1-5
