fisk33
I've successfully upgraded my P3 Pro at least two or three times since i bought it in June but tonight is my first failed upgrade. I tried to upgrade to P3X_FW_V01.05.0030.bin file and it failed. I tried several times to no avail. The first time it ran thru the upgrade process for at least ten minutes before the solid red light. each time since then, it's failed within 30 seconds. I even tried to put the v1.04.0010 file back on, but that failed also.
Here is some of the text on the Result_AB file starting with the last time i booted it up on the old version. I tried to upgrade to 05.0030 several times and then back to the 4 again
========== 2015.10.24 17:57:52 =====================
Packet: P3X_FW_V01.04.0010.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.05.0030.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
I've tried turning the aircraft off including pulling the battery for a while to fully reboot.
Here is the hidden log file.
[00014921]Version checking[1]...
[00015001][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015101][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[00015159][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015281][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015374][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015481][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015589][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015715][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028265][15 00][00] device not detected.
[00028370][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028497][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028555][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028609][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade
[00028662][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00041214][08 00][00] device not detected.
[00041297][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00041417]Done.
[00043467]Waiting for user confirm...
[00053518]Timeout, start upgrade automatically.
[00053620]Firmware upgrading[1]...
[00065113][01 00] Firmware upgrade start...
[00014248][01 00] Firmware upgrade finished successfully.
[00014299]Done.
[00014348]Packet [C:\P3X_FW_V01.05.0030.bin] resumed, card sn [0xc18c2ac2].
[00014403]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014462]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014512]Version checking[2]...
[00014597][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014677][03 06][00] v2.3.0.13 -> v2.4.0.5 need upgrade.
[00014731][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014837][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014931][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015028][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015122][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015231][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027799][15 00][00] device not detected.
[00027886][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028028][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028092][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028143][01 00][05] v1.26.4315 -> v1.26.4315
[00028199][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00040754][08 00][00] device not detected.
[00040854][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00040905]Done.
[00040955]Firmware upgrading[2]...
[00041114][01 01] Firmware upgrade start...
[00071378][01 01] Firmware upgrade finished successfully.
[00071619][03 06] Firmware upgrade start...
[00390048][03 06] Firmware upgrade finished successfully.
[00390122][09 00] Firmware upgrade start...
[00443634][09 00] Firmware upgrade finished successfully.
[00443706]Done.
[00443761]Version checking[3]...
[00443847][03 05][00] v34.2.0.9 -> v34.2.0.9
[00443923][03 06][05] v2.4.0.5 -> v2.4.0.5
[00443980][04 00][00] v1.41.0.0 -> v1.41.0.0
[00444101][11 00][00] v1.7.0.0 -> v1.7.0.0
[00444195][12 00][00] v1.10.0.0 -> v1.10.0.0
[00444315][12 01][00] v1.10.0.0 -> v1.10.0.0
[00444509][12 02][00] v1.10.0.0 -> v1.10.0.0
[00444595][12 03][00] v1.10.0.0 -> v1.10.0.0
[00457150][15 00][00] device not detected.
[00457231][17 00][00] v1.1.1.7 -> v1.1.1.7
[00457371][17 01][00] v1.0.2.7 -> v1.0.2.7
[00457431][19 00][00] v1.0.8.96 -> v1.0.8.96
[00457483][01 00][05] v1.26.4315 -> v1.26.4315
[00457535][01 01][05] v1.26.4315 -> v1.26.4315
[00470084][08 00][00] device not detected.
[00470152][09 00][05] v2.13.0.0 -> v2.13.0.0
[00470203]Packet upgrade failed at version checking.
[00014578]========== remo-con disconnect. boot(15) ============
[00014633]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xc18c2ac2].
[00014683]Packet upgrade start...
[00014735]Packet checking...
[00014786]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014847]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014897]Done.
[00014949]Version checking[1]...
[00015041][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015141][03 06][00] v2.4.0.5 -> v2.4.0.5
[00015197][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015341][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015454][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015554][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015654][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015781][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028349][15 00][00] device not detected.
[00028446][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028585][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028661][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028712][01 00][00] v1.26.4315 -> v1.26.4315
[00028767][01 01][00] v1.26.4315 -> v1.26.4315
[00041318][08 00][00] device not detected.
[00041401][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041458]Packet upgrade failed at version checking.
[00014574]========== remo-con disconnect. boot(15) ============
[00014630]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xc18c2ac2].
[00014681]Packet upgrade start...
[00014897]Done.
[00015025]Version checking[1]...
[00015112][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015198][03 06][00] v2.4.0.5 -> v2.4.0.5
[00015275][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015399][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015507][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015607][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015707][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015807][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028360][15 00][00] device not detected.
[00028462][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028605][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028678][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028731][01 00][00] v1.26.4315 -> v1.26.4315
[00028783][01 01][00] v1.26.4315 -> v1.26.4315
[00041337][08 00][00] device not detected.
[00041418][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041470]Packet upgrade failed at version checking.
[00014592]========== remo-con disconnect. boot(15) ============
[00014647]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0xc18c2ac2].
[00014700]Packet upgrade start...
[00014760]Packet checking...
[00014811]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014871]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014926]Done.
[00014979]Version checking[1]...
[00015095][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015195][03 06][00] v2.4.0.5 -> v2.4.0.5
[00015272][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015415][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015528][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015638][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015738][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015855][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028407][15 00][00] device not detected.
[00028519][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028663][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028730][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028782][01 00][00] v1.26.4315 -> v1.26.4315
[00028834][01 01][00] v1.26.4315 -> v1.26.4315
[00041387][08 00][00] device not detected.
[00041470][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041523]Packet upgrade failed at version checking.
[00014588]========== remo-con disconnect. boot(15) ============
[00014727]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xc18c2ac2].
[00014779]Packet upgrade start...
[00014846]Packet checking...
[00014897]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014951]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00015006]Done.
[00015061]Version checking[1]...
[00015154][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015234][03 06][00] v2.4.0.5 -> v2.3.0.13
[00015300][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015368][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015518][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015618][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015722][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015824][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015922][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028475][15 00][00] device not detected.
[00028563][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028725][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028789][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028845][01 00][00] v1.26.4315 -> v1.23.3419
[00028901][01 01][00] v1.26.4315 -> v1.23.3419
[00041455][08 00][00] device not detected.
[00041507]Packet upgrade failed at version checking.
I also redownloaded the bin file again. that also didn't work.
any ideas?
thanks,
Perry
