DJI-JS
Flight distance : 48940 ft
Hi Paras,
I am confused. In your original post, you mentioned:
Recording a video over the valley with perfect reception, suddenly the phantom starts accelerating at full speed away from me, until it reaches c.1050m (3350ft) distance, then turns upside down a couple of times and then stabilizes. I turn off the controller to activate come home and it starts coming towards me. When at 900m distance (2800ft) and 65% battery I turn off come home to bring it back manually and all connections break down. Never came back to home point, came back to my viewing or hearing range.
But now you said you kept your remote on.
If the connection is broke, the phantom will enter the fail safe mode, and commencing return to home process. During this process, if the S1 switch is at the top position (GPS mode), the control will be regain after reconnect AND S1 switch is moved. If S1 was at other position (manual or ATTI), the regain will be immediate after the phantom and TX connects again. And you mentioned you were not flying in GPS mode, so the control will be regain immediatly after the quad reconnected to the TX. So if you kept TX on all the time, there could be a short time period that the signal from TX was intermittent, and that could ruin the return to home process.
Usually when return to home is actived, turn off the TX is a good idea. And turn it back on when you sure the connection will be solid.
