P3P camera won't point straight forward
935 6 2015-12-7
michael.tristra
Flight distance : 769042 ft
Hi,
I am having a problem with my camera on my P3P. It has been perfect and I've only had it for about 3 months. For some reason the camera now points to the left about 6 - 7degrees and won't point staright forward. The horizon is level, just the camera isn't pointing straight forward. I have tried mutiple IMU calibrations, in the fridge and room temperature followed up each time with a gimbal calibration. It goes straight temporarily and then it creeps back to point to the left again. Any ideas?
2015-12-7
DJI-Amy
Hi, please try to change the aircraft heading and turn on the aircraft again. In your case, you might have turned on the aircraft when it was heading the north, the gimbal pan will turn to left a little bit, then it will re-center after 10-15 seconds.
2015-12-15
michael.tristra
DJI-Amy Posted at 2015-12-16 17:31
Hi, please try to change the aircraft heading and turn on the aircraft again. In your case, you migh ...
Hi Amy,
That is not the problem. See this thread below for video of the problem and discussion of what is happening.
http://forum.dji.com/forum.php?m ... mp;page=1#pid266304
I am still awaiting a response on how to fix it.
Regards,
Michael
2015-12-16
DJI-Patrick
michael.tristra Posted at 2015-12-16 21:06
Hi Amy,
That is not the problem. See this thread below for video of the problem and discussion o ...
Hi , Michael
Please check the screw hole in the picture I attached in my reply . Please keep it updated if the problem can't be solved by that way .
2015-12-16
michael.tristra
DJI-Patrick Posted at 2015-12-17 17:20
Hi , Michael
Please check the screw hole in the picture I attached in my reply . Please keep it up ...
That screw is tight and is not the problem.
2015-12-17
DJI-Patrick
michael.tristra Posted at 2015-12-17 18:21
Alright . I'll report that to R&D .
2015-12-17
michael.tristra
DJI-Patrick Posted at 2015-12-17 21:28
Thank you.
2015-12-17
