renebertschi.gm
Flight distance : 620620 ft
I was one of the victims that experienced a flyaway, but the damage was minimal, but it started an inquiry in to what can cause this phenomena? So the first thing I did was to contact DJI servise and gave them two articles about interference with 5 to 5.8 GGz and 2.4 GHz of the radio spectrum frequency.
I received the following (see below)
Dear Rene,
Thank you for contacting DJI. The best way to prevent interference is to make sure that everything is calibrated and that the firmware is updated properly. Also be cognizant of your surrounding. If you are near an area that has a Wi-Fi, then you have to make the determination on whether it is a good idea to fly the unit or not as these things can cause interference. I hope that helps.
DJI Customer Service North America.
This was not what I was looking for, or expected from such a top tier company?
Avoiding Interference in the 2.4-GHz ISM Band.
http://www.eetimes.com/document.asp?doc_id=1273359
and
Avoid interference between 5 GHz Wi-Fi and 5.8 GHz cordless phones.
http://bradsfavorite.com/avoid-i ... ghz-cordless-phones
I hope this will shed some light on the subject.
Rene |
