X5/Gimble Drifting
12Next >
5913 45 2015-12-8
will
Flight distance : 97545420 ft
Hi everyone, long time lurker here and the forum has helped me out a lot over the years (thanks!).
I've recenty upgraded my Inspire to carry the X5 and the initial thoughts are positive. From early on though, I've noticed that the camera was ever so slightly moving about, as if the IMU was not calibrated, or that the surface it was on wasn't stable.
In flight, whilst hovering, this movement/drift is magnified and very noticeable. I've had the Z15 GH4 and NEX gimbals, plus the old X3 and this is way beyond what I would expect from this system.
The firmware is fully updated and I calibrated the IMU and compass, as per the DJI reccomended ways.
Any thoughts or advice greatly appreciated.
Will
2015-12-8
DJI-Ken
Flight distance : 1515312 ft
And you've also done a gimbal calibration too correct?
2015-12-8
teamnest1
Flight distance : 18484 ft
DJI-Ken Posted at 2015-12-8 17:49
This, hopefully that fixes it
2015-12-9
DJI-Ken
I'm hoping too, if not let us know and we'll keep trying.
2015-12-9
CloudVisual
Gimbal calibration was completed. It's not done anything to fix it. The gimbal behaves as if it's drunk and every now and then has a bit of a sway when stationary on the ground and even worse in the air.
2015-12-23
jedrzej
Denmark
Did you manage to get to the bottom of it and fix the issue ? I have similar problem with my x5 after the latest update.
2016-1-4
mechanicus
Flight distance : 21086 ft
I have the same problem. running the latest fw. Even when on the ground motors shutoff the gimbal is drifting.
DJI Help please!
ps. running a Pro with a X5
2016-1-6
ayrshireuav
Flight distance : 957297 ft
I too have the same issue.  Just back from a cold day in the country and every image taken is blurry, the video is poor quality and the gimbal/camera look like its 2 days behind everything else.  It hangs slightly too and thats after the updated firmware, configuration of all things etc.  Im cold and I'm raging.  The onscreen images looked great too.
2016-1-6
HEJM
Flight distance : 872362 ft
Same Issue here! Gimbal calibration does not help and IMU calibration says there is no need to calibrate.
2016-1-6
DJI-Ken
Reset all settings should fix that. make sure to write down all your settings first.
2016-1-6
domidragon90
Switzerland
Reseting all the settings doesnt help!
Deactivating the synchronous gimbal checkbox helped to eliminate the drifting for me. (Have a look in the gimbal  settings - advanced settings)
Give DJI and me a feedback if it works.
2016-1-8
mechanicus
DJI-Ken Posted at 2016-1-6 20:40
Ken does this mean the bad video is part of it as well?
http://forum.dji.com/thread-39238-1-1.html
2016-1-8
DJI-Ken
mechanicus Posted at 2016-1-9 01:42
http://forum.dji.com/thread-39238-1-1.htm ...
Have you done all the calibrations, including gimbal calibrations? and also adjust exposure, ISO, Shutter Speed, ?The X5 is a complex camera and not for beginners, fi you Google DJI X5 camera setting, or camera solutions, you will find a lot of information out there. I have not had a chance to fly a X5 yet so I am not very familial with all of it's settings.
2016-1-8
Fink
My X5, which came on my Inspire 1 Pro, also has the gimbal drift. Mine is far more noticeable on the ground.
2016-1-8
DJI-Ken
Fink Posted at 2016-1-9 08:17
My X5, which came on my Inspire 1 Pro, also has the gimbal drift. Mine is far more noticeable on the ...
Fink,
Can you please post a video
2016-1-8
mechanicus
DJI-Ken Posted at 2016-1-9 06:37
Fink,
Here is mine!
2016-1-9
Positveimage
Flight distance : 2772 ft
DJI-Ken Posted at 2016-1-8 17:49
Have you done all the calibrations, including gimbal calibrations? and also adjust exposure, ISO, S ...
Hi Ken,
In the Go app, what is the setting: Gimbal Yaw Synchronous Follow? It's in Gimbal, advanced settings, configuration.
Many thanks
2016-1-9
DJI-Ken
Positveimage Posted at 2016-1-9 20:18
Hi Ken,
In the Go app, what is the setting: Gimbal Yaw Synchronous Follow? It's in Gimbal, advance ...
It smoothes out the camera on yaw movements. You can see with it on, move the yaw back and forth and the camera will pan a little.
Turn it off and the camera won't move when you yaw on the ground.
2016-1-9
DJI-Ken
mechanicus Posted at 2016-1-9 17:48
Here is mine!
https://vimeo.com/151221474
If you reset all setting will that help.?
2016-1-9
mechanicus
DJI-Ken Posted at 2016-1-9 16:50
Nope not at all. Reset the settings, disabled Gimbal Yaw Sync and no improvement.
I'm inside now (with no flight) and the gimbal goes everywhere.
See it drifting and I move the gimbal a few times fast but the small moves are not comming from me.
2016-1-10
DJI-Ken
mechanicus Posted at 2016-1-10 21:37
I'm inside now (w ...
You've also done a IMU calibration on perfectly level surface correct?
If resetting and all the other things you've done cannot get rid of the drift, then you need to contact the support center and get it repaired under warranty. And include doth videos here.
Sorry about the issue you are having.
2016-1-10
mechanicus
DJI-Ken Posted at 2016-1-10 16:55
If resetting and all the ot ...
Just did it and it doesn't change.Setting seem to be ok.
One other thing. It is expected to calibrate or autocalibrate on a flat level.
Is DJI aware that that is almost not possible to see when you are in the field.
Wouldn't it be nice to have some sort of bubble on each legg so you can level the bird before calibrating. I'm sure a lot of problems will disappear if it is so important.
2016-1-10
Casey Preston
I've had access to two X5 gimbals.  I've tried calibrating the gimbals in multiple settings and running through all of the options.  The X5 always drifts slightly.  I've just come to the conclusion is it is the nature of the gimbal.  Of course, I've also seen the X3 drift, it's just little less noticeable because the field of view is wider than on the X5.
2016-1-10
mechanicus
Casey Preston Posted at 2016-1-10 22:39
I've had access to two X5 gimbals.  I've tried calibrating the gimbals in multiple settings and runn ...
If so.... we have a problem Houston!
The apparatus cost a little fortune and if this is the quality I call for a little revolution.
I refuse to believe this is the nature of the beast. For what I have purchased it must be possible to solve it. We are talking high end right?
2016-1-10
Casey Preston
I should add that my Ronin is almost rock solid.  I have the Osmo and a couple X3's and I have tried the two X5's  The X3's and X5's drift slightly on the Inspire and the X3's drift on the Osmo.  I have assumed that it is a motor versus tuning vs electrical interference issue, but I only half know how the gimbals work and what to expect.  For my intended uses, the drifting is not a concern.  If I want a steady shot, I use a camera and a tripod.  If, however, DJI has created a product that is supposed to be rock solid when not under load, then something is wrong.
2016-1-10
mechanicus
RE: X5/Gimble Drifting
Casey Preston Posted at 2016-1-10 23:53
I should add that my Ronin is almost rock solid.  I have the Osmo and a couple X3's and I have tried ...
"If, however, DJI has created a product that is supposed to be rock solid when not under load, then something is wrong."
My thoughts exactly. How about long exposures... For me one of the reasons I purchased.
2016-1-10
domidragon90
Switzerland
Hm like I said, it fixed for me to deactivate the sync gimbal setting. It is a workaround, but not a solution!
2016-1-14
Jwmulcahey
Flight distance : 396142 ft
Did anybody else come up with a solution on this? Mine drifts as well, not all the time but enough to notice it in flights. Tried IMU calibration, gimbal calibration, deactivating sync gimbal setting and nothing has helped. It's quite annoying to constantly have to adjust a $2200 gimbal/camera set up in flight, plus it makes getting straight moving footage nearly impossible with the gimbal constantly moving.
2016-1-21
jmtrahan00
Any update on this?   Its getting frustrating that we are all seeing gimbal drift/horizon level issues and no solution has been provided yet...    Seems that every new firmware released seems to create new gimbal related issues..
2016-2-9
CloudVisual
The weather in the UK has been really bad. Got a chance to head out yesterday and the problem still exists. Exactly as shown in the videos people have posted in this thread.
Has DJI been able to recreate this or have anything lined up in a future update?
2016-2-17
jonathanp
Flight distance : 519275 ft
Which Gimbal mode are you in?  Does the problem happen in both "follow-me" & "free mode" ?
2016-2-17
jonathanp
I've noticed the drift in "follow-me" mode.  However in free mode the gimbal seems to be rock solid.  Here's an example video with the gimbal locked in "free mode":
2016-2-17
jaabsfilms
India
DJI-Ken Posted at 2015-12-9 04:19
I also having the same issue with my new x5 Gimbal. And I updated the new  firmware which released few days before. But the issue is still the same. I dnt know wat to do.
2016-3-13
jaabsfilms
India
I am also having the same issue. Even I upgraded new firmware yesterday. But the issue not solves. Dont know wat to do. Kindly help
2016-3-13
jaabsfilms
India
domidragon90 Posted at 2016-1-8 16:49
Deactivating the synchronous gimbal checkbox helped to elimi ...
Yess its worked with me also
2016-3-14
jaabsfilms
India
mechanicus Posted at 2016-1-10 22:12
One other thing. It is expected to calibr ...
Deactivating the synchronous gimbal checkbox helped to eliminate the drifting for me. Its working perfectly now. now my x5 is rock steady
2016-3-14
jaabsfilms
India
jaabsfilms Posted at 2016-3-14 12:25
I am also having the same issue. Even I upgraded new firmware yesterday. But the issue not solves. D ...
Deactivating the synchronous gimbal checkbox helped to eliminate the drifting for me. Its working perfectly now. now my x5 is rock steady. Go to Gimbal setting> advance settings >
2016-3-14
jaabsfilms
India
DJI-Ken Posted at 2015-12-10 02:41
2016-3-14
DJI-Ken
jaabsfilms Posted at 2016-3-14 19:06
Deactivating the synchronous gimbal checkbox helped to eliminate the drifting for me. Its working  ...
Glad you found a solution.
2016-3-14
domidragon90
Switzerland
thats not a solution, it's only a workaround. please fix it!
2016-3-21
12Next >
