Effective Range of Phantom 2 Vision +
1359 5 2014-12-26
jmims
Flight distance : 1686991 ft
Been flying the Phantom around the neighborhood. Taking off at a park, cruising around 200 - 300 ft up and heading off to find my house. I'm losing signal about 700 - 800 ft. I can't see the Phantom for the trees and the houses in the way. I'm assuming that's why I'm not getting 1000+ range. What is everyone else's experience? Any way to improve distance? Parhaps a higher altitude?
2014-12-26
Gerry1124
Trees, buildings or anything blocking a direct line of sight will block your signal.
2014-12-26
droneflyers.com
Flight distance : 60709 ft
Remember, anything other than LOS (line of sight) flight is outside the operating parameters of this type of craft. You are much more likely to lose your quad completely flying in this manner. In fact, it's almost a certainty you will be parted with it.
Depending on your eyes and the conditions outside, most Phantoms would be a dot in the sky at 350 feet high - let alone off in the distance. It's your money, but I only fly my Phantom where I can easily recover it and never to experiment how far I can get it to go, etc.
2014-12-26
jqhnny10
while i am flying my pv2+ i lose video feed on my phone but i can still fully control drone.  just cant see what it sees.  this happens even 20 feet from me  anyone know why
2014-12-27
jmims
jqhnny10@yahoo. Posted at 2014-12-28 13:32
while i am flying my pv2+ i lose video feed on my phone but i can still fully control drone.  just c ...
The iPhone will use the strongest WiFi signal. That means that if you are flying near your house, once your Phantom's signal is weaker than your home signal, the iPhone will revert to the wrong WiFi. Just "forget" your home WiFi and see if that solves the problem.
2014-12-28
Gerry1124
Some phones have an automatic "search for better wifi"  Check in your phone settings and turn that off if you have that.
2014-12-28
