DJi Go does not save the value of the setting
1594 15 2015-12-12
JK JK
Flight distance : 652552 ft
Czechia
I want to change the settings for Joysticks, but DJI Go does not save new values. How to solve it?
Video:
2015-12-12
JK JK
Czechia
Wow, no one cannt help me? No one from DJI? Expensive and good products with pretty pure support?
2015-12-14
DJI-Ken
Flight distance : 1515312 ft
It should keep your values, can you delete the app and re-install and see if it still does it.
2015-12-14
JK JK
Czechia
I will try it, but it seems I am not alone who has actualy the same issue
http://forum.dji.com/forum.php?m ... mp;page=1#pid269204
2015-12-16
JK JK
Czechia
DJI-Ken Posted at 2015-12-14 19:09
DJI-Ken
I uninstalled, cleared my smartphone by SD-maid and install DJI Go again. Unfortunately no change. :-(
2015-12-16
DJI-Ken
What Phantom do you have and are you on the latest updates?
Also, do you have enable device debugging on. If not, there's instructions on Google on how to do it.
Your on 2.4.3 now since yesterday right?
it seems to be something within the app and your phone. Can you try another device and see if that works.
I'll copy this and post it on the other thread you responded to.
2015-12-16
JK JK
Czechia
SAMSUNG S5, ANDROID 5
2015-12-16
JK JK
Czechia
Samsung S5, Android 5.0, Phantom 3 Pro, the latest FW and DJI Go (see end of the video), USB debug = ON. I will try to test with another phone.
2015-12-16
DJI-Ken
Yes, please try a different phone and let us know. It has to be your phone not working 100% with the app. There's nothing wrong with the app.
2015-12-17
JK JK
Czechia
HI,
I think I have found the source of the issue. It seems to be a bug in the Android app version.
Samsung SGS5 Android 5.0 - can not set the expo
Samsung SGS7 Android 5.1.1 - can not set the expo
Nexus Asus 7“ Android 6.0.1 - can not set the expo
iPhone 5S – works
iPhone 6 - works
I am sure, that the issue is related to Android.
2015-12-17
quanthonytrang
Flight distance : 419980 ft
JK JK Posted at 2015-12-18 18:47
HI,
Instead of sliding to change values, manually type the value with a decimal point. There is comma in the value and hence the DJI go app cannot validate. If you cannot type the value, start a typing app on your phone and enter 0.20 (your value) and copy as paste it. ALL 3 values MUST be a valid number before it can write the changes.
2015-12-18
DJI-Ken
I just noticed that in the video, it's suppose to be a decimal point.
2015-12-18
JK JK
Czechia
Yes, it is the decimal point
2015-12-18
JK JK
Czechia
When you use the curve to change the number, than it generated number without decimal point (i.e. 030) which is out of range. If you want to rdit the number in the cell bellow the curve then the comma "," is expected, but you can type only dot ".". It is usual bug in Android app as I figured out already.
2015-12-18
santitimerman
Flight distance : 3085112 ft
Argentina
same problem
2016-2-9
vdsky
Flight distance : 906831 ft
Latvia
I can confirm, that changing , to . works. But, if faili first time, keep trying. My values have been saved after 3 attemts...
2016-9-13
