Z15-GH4 not working
935 4 2015-12-14
Goleosky
Poland
Hello.
I have a problem with my Z15-GH4 gimbal mounted in the DJI S1000 + A2. I use it with the TX Futaba T14SG (for the pilot) and TXGraupner MX16 (for camera operator).
Until now, it was all right. I flew with this set few months without problems. Because of non-flying jobs I did not have time to fly last month. Today I connected the set and gimbal behaves strangely, as seen in the video:
As you can see in the video, gimbal trying to calibrate, but doing it in a way other than it should. I tried it a few times to connect, but the effect is similar. Sometimes the yaw axis begins to rotate very quickly.
I use image transmission AVL58 and it works OK now. Gimbal software and firmware is up to date.
After plug-in gimbal to the DJI Zenmuse Assistant is connection. When I move bars in camera operator TX, I see a changes in Assistant, but gimbal does not turn in any axis. Likewise, when changing the mode several times to restart the gimbal, I see the Assistant switching, but gimbal don't restart.
Can anyone help me?
Regards,
2015-12-14
Richardrambone
Flight distance : 298100 ft
4 more points
2015-12-14
DJI-Amy
Please contact DJI technical support for repair, it's hardware problem.
2016-1-8
Aerial Master
DJI-Amy Posted at 2016-1-8 04:04
My z-15 gh4 av out has terrible noise with lines running from bottom to top. I installed a new av board and it didn't fix it. What do I do?
2016-2-9
DJI-Amy
Aerial Master Posted at 2016-2-10 15:56
My z-15 gh4 av out has terrible noise with lines running from bottom to top. I installed a new av  ...
Sorry for the late reply since I just returned from the Chinese lunar year.  Could you provide a video to indicate your problem? That would be helpful. Thanks.
2016-2-14
