Kneepuck
Flight distance : 275105 ft
If you have verified signal out from the hdmi module then I would have to examine the resolutions or signal formats. This is assuming your sd convertor is also verified good. Cables, resolution compatability, and whatever you are inputting the signal into. That may not accept the signal you are feeding it. Sorry, without knowing more about your application, to many variables, but should be pretty straight foreward. Does your sd convertor have rca jacks, is it a composite output?
