Inspire 1 Camera Setting for Land Survey
2404 5 2015-12-16
niall
Hi all
Been using my Inspire 1 for some surveying, getting great results. Stuff like this: https://www.mapsmadeeasy.com/map ... a1a2262428966b6585/
The map Piliot app for iPad is excellent, very easy to use and process with maps made easy.
Trying out Pix4D also, alot more detailed and complex, but getting used to it.
Anyway, Has anyone else been doing the same? Any tips on camera settings to get better resolution in the final product?
Thanks
Niall
2015-12-16
MikeFrey
Flight distance : 4661821 ft
Hi Niall, RAW images should provide better resolution than jpeg if you have not tried that already. I have done some of this type of work by taking photos with the inspire 1 and uploading them via the home computer. I did mine with the 123D app. The more photos you upload, the better the result seems to be. Are you using the X3 or X5 camera?
2015-12-16
Edward
Flight distance : 1555663 ft
British Virgin Islands
Niall - I have also been using the Maps Made Easy app with Inspure and agree entirely that it is simple to use and produces high quality images. From what I can see, you can only upload jpegs in this programme. I would be interested to hear more about your experiences with Pix4D as I have been looking at that too. Some of the applications seem to provide additional output compared to MME so will be interested in this app once it is released for IOS.
2015-12-16
SixtyMike
Niall, thanks for posting this.  I'm looking at using MME next month to survey my place (Inspire/X3).  Regarding your "Home Test", can you post the altitude and speed you used along with cm/pixel?  Also interested in the overlap percentages.
Again, thanks for posting.
60
2015-12-17
GB44
Flight distance : 343848 ft
I have used Pix4D Mac beta testing and am not that impressed with the quality at the minute.
Had problems inputing temporary ground points using GPS Eastings and Northings or even Lat and Long coordinates.
Also has some initial issues rendering images on a mac.  The software seem to be using the power faster than it was actually being charged.  Now upgraded mac which has a higher charger capacity and not had any more problems on that point.
2015-12-17
Adam_Geomatics
Hi,  KlauGeomatics has announced a new PPK GPS technology for accurate aerial surveying using DJI drones without placing ground targets. See https://www.veritypositioning.com/ for more details.
2018-1-4
