DJI-Amy
Hi, alan, the 4G split mechanism is designed to avoid the file damage risk. For FAT32 format SD card, it can support 4G size for single file at most. Files larger than 4G can't be saved in the SD card. For ExFAT, the corrupted probability of file larger than 4G can be very high, so we design this mechanism in order to protect the data. Because once the file is corrupted, the whole work is unusable any more. Yes, this mechanism is not perfect right now since it might loose a few data frames when cutting the files into 4G. I will report your need to the corresponding engineers. Thanks, alan. |
