terrylewis
Flight distance : 3517287 ft
Hi LIcampe,
For your P3A upgrade, you should power everything off. Put the sdcard into the camera slot and only power up the aircraft. No RC or GO App.... It's also recommended that you format your sdcard using the P3. Cards 32GB or greater should be ExFat, cards 16GB or smaller Fat16 if you use your computer....
With the simulator, the P3 should have it's props removed. Power up the RC, then the P3, and finally the GO App. The P3 is needed for simulator telemetry.
